Hotjar connection guide
This guide contains all permissions and requirements for connecting your Horjar data to Supermetrics.
Before using the Hotjar connector, make sure that your Hotjar plan includes access to their API. See this Hotjar support article for information on how to subscribe to API access.
To connect Supermetrics to your Hotjar account, you need to generate API credentials (client ID and client secret) as well as the site ID for the site you want to fetch data for.
Step 1: Generate API credentials
  1. Log in to the Hotjar platform.
  2. Open the Organization Settings page
  3. Click API from the left menu bar.
  4. Select your organization.
  5. Enter a name for the credential, for example “Supermetrics”.
  6. For scopes, select “Survey responses”.
  7. Click Generate credentials.
  8. Copy the Client ID and Client secret to a safe place for later reference.
Step 2: Get your site ID
  2. Open the Sites & Organizations page.
  3. The site ID is in the left-most column in the table, next to the site name.
  • Surveys: Behavior analytics and feedback data to help users empathize and understand their customers through surveys tool.
When connecting to Hotjar, you need to provide your API credentials.
  1. Select the Hotjar data source on the Supermetrics Hub or in the data destination.
  2. Enter your client ID, client secret, and site ID.
  3. Give a name for your site so you can identify it later.
  5. Click Start.
  6. In your data destination, select the query type, if prompted
You can also connect to Hotjar from these destinations:
