This guide contains all permissions and requirements for connecting your Glassdoor Reviews data to Supermetrics.
You can query publicly available company review data from Glassdoor Reviews without logging in to Glassdoor.
To pull data on a company on Glassdoor, you'll need to copy the company's identifier — called its company ID — from its Glassdoor URL.
For example, if a company's Glassdoor Reviews URL is glassdoor.com/Reviews/Supermetrics-Reviews-E1234567, its company ID is 1234567.
Reviews: Fetch up to 1,000 of the latest public reviews for a company.
When connecting to Glassdoor Reviews, you need to enter the company IDs to query.
Select the Glassdoor Reviews data source on the Supermetrics Hub or in the data destination.
In your data destination, enter the company ID and the language you'd like to pull reviews for.
You can also connect to Glassdoor Reviews from these destinations:
AI tools and dashboards:
