This guide contains all permissions and requirements for connecting your Flashtalking data to Supermetrics.
Before using the Flashtalking data source connector, you need the following:
A Flashtalking username and password. The username and password are the same as those you use to log in to the Flashtalking Hub Reports application.
API access for your Flashtalking account, including access to the Campaign Manager API.
Campaign: Measure paid media performance. Get data about clicks, cost, and interactions. Group the data by date, content, placement, advertiser, and so on.
Spotlight: Measure the performance of your spotlights
When connecting to Flashtalking, you need to insert your Flashtalking username and password and select the account when prompted.
Select the Flashtalking data source on the Supermetrics Hub or in the data destination.
Enter your username and password.
In your data destination, select the accounts to use in your reporting and a query type, if prompted.
You can also connect to Flashtalking from these destinations:
AI tools and dashboards:
