Facebook Insights connection guide
This guide contains all permissions and requirements for connecting your Facebook Insights data to Supermetrics.
To connect Supermetrics to Facebook Insights, you need Administrator access to the Pages you want to pull data from. If you're connected with Business Manager, you'll need at least Page editor access to those Pages.
Visit the Facebook help center to learn more about adding permissions to a Page and adding users to a Page in Business Manager.
If you're using the new Pages experience, your account needs Partial access to the linked Page.
When connecting to Facebook Insights, you need to log in to Facebook and select the Businesses and Pages to include in your reporting when prompted.
  1. Select the Facebook Insights data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Either log in with a new Facebook account, or click Continue as to go ahead with the account you're already logged in to.
  5. Select the Businesses and Pages you want to include in your reporting.
  6. Review the permissions, and click Save.
  7. Click Got it.
  8. In your data destination, select the pages you want to add to your reporting.
You can also connect to Facebook Insights from these destinations:
