Everflow connection guide
This guide contains all permissions and requirements for connecting your Everflow data to Supermetrics.
To connect Supermetrics to your Everflow account, you need to create an API key.
Create an API key
  1. Log in to the Everflow platform
  2. From the left menu, expand the menu by clicking on the arrow icon at the bottom.
  3. From the menu navigate to Control CenterSecurity.
  4. Click + API key.
  5. Give a name for your API key, select the employee, and select at least the permission Reporting.
  6. Click Create API Key.Your key will be displayed in the Generated Keys table.
  • Performance: Measure the performance of your affiliate partners.
When connecting to Everflow, you need to provide your API key.
  1. Select the Everflow data source on the Supermetrics Hub or in the data destination.
  2. Enter your API Key.
  5. Click Start.
  6. In your data destination, select a query type to use, if prompted.
You can also connect to Everflow from these destinations:
