This guide contains all permissions and requirements for connecting your Close CRM data to Supermetrics.
Before using the Close CRM connector, you need to create an API key on the Close platform.
How to obtain your API key:
Navigate to Settings → Developer → API Keys.
Click + New API Key to create a new key.
Provide a meaningful name for the key that helps you identify which integration it's used for.
Once the key is created, copy and store it securely. You’ll only be shown the full key once — after that, only a shortened reference will appear in your settings.
Leads: Pull all the dimensions and metrics for your leads, filtered by created or updated date.
When connecting to Close CRM, you need your API key.
Select the Close CRM data source on the Supermetrics Hub or in the data destination.
Enter the API Key.
In your data destination, select the organizations to include in your reporting and a query type, if prompted.
You can also connect to Close CRM from these destinations:
AI tools and dashboards:
