This guide contains all permissions and requirements for connecting your ChatGPT Ads data to Supermetrics.
To connect Supermetrics to your ChatGPT Ads data, you need an API key generated from the OpenAI Ads Manager. You must have Admin permission to generate API keys.
To get the API key:
Go to the OpenAI Ads Manager settings page.
Create a new API key.
Copy the generated API key.
When connecting to ChatGPT Ads, you need to insert your API key when prompted.
Select the ChatGPT Ads data source on the Supermetrics Hub or in the data destination.
Enter your API key generated from the OpenAI Ads Manager.
You can also connect to ChatGPT Ads from these destinations:
