This guide contains all permissions and requirements for connecting your Campaign Monitor data to Supermetrics.
To connect Supermetrics to Campaign Monitor, you need a Campaign Monitor account with an Admin user role.
Campaign summary (sent): Follow your email campaigns' performance.
When connecting to Campaign Monitor, you need to log in to Campaign Monitor.
Select the Campaign Monitor data source on the Supermetrics Hub or in the data destination.
Enter the email address and password you use with Campaign Monitor.
Click Continue, and then Allow access.
In your data destination, select the account to use and a query type, if prompted.
You can also connect to Campaign Monitor from these destinations:
AI tools and dashboards:
