CallRail connection guide
This guide contains all permissions and requirements for connecting your CallRail data to Supermetrics.
To connect Supermetrics to CallRail, you need:
Note
CallRail's API usage is based on tiers. 0-1500 API calls per month are free but heavier usage may incur additional charges from CallRail. More information on CallRail's API tiers is available here.
  • Calls
    • Returns data on calls and leads acquired through calls. Find metrics like the number of calls, answer rate, call duration, lead amount, and lead value.
    • Gathers data about call insights by splitting the data by time, call source, number, or agent. This can help with resource planning and identifying the best-performing agents.
    • Gathers data on a specific call and fetches direct links to recordings.
  • Form submissions
    • Returns data on form submissions and leads acquired through forms. Find metrics like the number of form submissions, lead amount, and lead value.
    • Gathers lead insights by splitting the data by time or by source. You can also fetch all form submission data to dig into specific answers.
When connecting to CallRail, you need to provide your API key and select the accounts to use when prompted.
  1. Select the CallRail data source on the Supermetrics Hub or in the data destination.
  2. Enter your API key.
  4. Click Start.
  5. In your data destination, select the accounts you'd like to include in your reporting and a query type to use.
You can also connect to CallRail from these destinations:
