Brevo connection guide
This guide contains all permissions and requirements for connecting your Brevo data to Supermetrics.
To connect Brevo to Supermetrics, you need an API key. Remember to keep this safe once you have it.
Create an API key
  1. Log in to Brevo.
  2. Click your account's name in the top right corner.
  3. Select SMTP & API.
  4. Go to the API keys tab.
  5. Click Create a new API key.
  6. Enter a name for your API key (for example, “Supermetrics”).
  7. Click Generate.
  8. Copy the API key from the list under "Your API keys".
Learn more about API keys in Brevo's documentation.
  • Email campaigns: Pulls the most popular performance metrics for email campaigns
When connecting to Brevo, you need to provide your API key.
  1. Select the Brevo data source on the Supermetrics Hub or in the data destination.
  2. Enter your API key.
  5. Click Start.
You can also connect to Brevo from these destinations:
Brevo errors due to unauthorized IP addresses
Brevo's API requires API calls to come from pre-authorized IP addresses. Supermetrics, however, uses dynamic IP addresses that change regularly, leading to connection errors when Brevo blocks unrecognized IPs.
You can select a suitable setting for handling unknown IP addresses in Brevo's settings:
  • Automatic IP review and authorization: Brevo automatically authorizes IP addresses used within the first 30 days of API key creation. After this period, new IPs will require manual review. If enabled before the 30-day period ends, existing IPs may be blocked unless manually added to the authorized list.
  • Manual IP authorization: Manually review and approve each unknown IP before allowing API calls.
  • No IP review: Allow all unknown IP addresses to make API calls without any review.
Learn more about the IP address authorization methods from Brevo's documentation and follow Brevo's instructions for setting up IP address handling that works for you.
