About limited data transformations for Pro and Growth subscriptions
Some Supermetrics users with a Growth or Pro package can run a limited number of Data blending and Custom fields queries — or data transformations — and use them in the data destinations you have access to. Check your subscriptions page on the Supermetrics Hub if you have access to limited data transformations!
You can use the Data blending and Custom fields to blend different data together and build fields that fetch particular data that supports your precise use case.
Take a look at these support articles to learn more about various types of transformations you can apply to your data:
With Growth and Pro packages, you can run 50 Data blending and Custom field queries per month. If you need more, contact us to upgrade your Supermetrics subscription to the Enterprise package and get unlimited access to the Data blending and Custom fields features.
How does it work?
You can start building your data transformations on the Supermetrics Hub, under Manage.
Follow these instructions to get started with transforming your data:
You can run 50 Data blending or Custom fields queries per calendar month. The number of queries you can run resets at the end of each month. Note that you can create an unlimited number of data blends and custom fields — the limit of 50 queries per month applies only to queries that you run.
In this context, a query is data being loaded successfully to a destination. See the table for what counts as a query and how different queries or refreshes use your quota.
Example
Number of queries used
User creates a new query on the Supermetrics Hub and runs it for the first time in their data destination
1 query
User refreshes the query in their data destination with the same parameters and the data comes from our cache
0 queries
User changes a parameter in the query and the data is fetched from the source API
1 query
User loads a Looker Studio dashboard several times and the data doesn't come from the cache
As many queries as the times the dashboard and its queries are refreshed with new data from the API
(To avoid hitting the 50 queries limitation, disable Looker Studio’s automatic refresh)
User creates a data blend with 7 custom fields in it and runs the query
1 query
User creates 50 different queries using Custom fields and Data blending and runs all of them at once
50 queries
User creates a query, runs it, and the query fails
0 queries
User creates a query and sets it to refresh daily
28 to 31 queries, depending on the number of days in a month
User runs a data blend query with 100 accounts, 50 metrics and 50 dimensions
1 query
Follow these best practices for using limited data transformations:
  • Disable automatic refresh: In data destinations like Looker Studio, disable the automatic refresh feature by activating the Pause updates button while working on a dashboard. If a dashboard is refreshed multiple times and the data doesn't come from the cache, each refresh will use up one query from your quota.
  • Be aware of multiple simultaneous queries: If you need to use multiple custom fields or data blends, try to combine them into a single query. For example, creating a data blend with multiple custom fields within it will only count as one query. Running many different queries at once will quickly use up the quota.
  • Be mindful of query parameters: Refreshing a query with the same parameters when the data is from Supermetrics' cache does not count as a new query, but changing a parameter counts as a new query.
