This guide contains all permissions and requirements for connecting your Yext data to Supermetrics.
To connect Supermetrics to Yext, you'll need a Yext app and an API key.
Step 1: Create an app
Log in to Yext and open your dashboard.
On the left-side menu, click Developer and then Developer Console.
Click + Add an app in the top right corner.
Give a name for your app ("Supermetrics", for example) and click Create app.
Click the API Credentials tab and select these permissions:
Analytics: Read-only
Account settings: Read-only
Click Save.
Step 2: Get your API key
After saving your app, navigate to API Credentials and then API Keys.
Click the eye icon to show the API key.
Copy the API Key. Be careful to keep it secure.
When connecting to Yext, you need to provide your Yext API key and select the account to use.
Select the Yext data source on the Supermetrics Hub or in the data destination.
Enter your Yext API key.
Give your login a name to recognize the login later in case you have multiple logins.
In your data destination, select the account to include in your query.
You can also connect to Yext from these destinations:
