Yelp Reviews connection guide
This guide contains all permissions and requirements for connecting your Yelp Reviews data to Supermetrics.
You need a business' Yelp Business ID before you can pull its review data from Yelp Reviews.
You can find any Yelp Business ID by copying the text that comes after /biz in the URL for any business' Yelp page.
For example, if you opened the Yelp page for a business called Article Example Business, its URL would end with /biz/article-example-business. Here, the business's Yelp Business ID is article-example-business.
  • Reviews: Get data for up to 100 of the most recent reviews.
When connecting to Yelp Reviews, you need to enter the Yelp Business ID to query.
  1. Select the Yelp Reviews data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. In your data destination, select a query type, if prompted, and the Yelp Business ID to include in your reporting.
You can also connect to Yelp Reviews from these destinations:
