Xing Ads connection guide
This guide contains all permissions and requirements for connecting your Xing Ads data to Supermetrics.
To fetch data from Xing Ads, your personal Xing account must be an Administrator of an Agency advertising account in Xing’s AdManager. Also ensure that your access has access to each of the customers in the AdManager that you wish to fetch data for.
  • Ads: Measure the performance of your paid advertising.
When connecting to Xing Ads you need to log in to Xing and select the accounts to pull data from.
  1. Select the Xing Ads data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Enter your Xing account credentials and click Log in.
  5. In your data destination, select the accounts to use in your reporting.
You can also connect to Xing Ads from these destinations:
