This guide contains all permissions and requirements for connecting your X Organic (Twitter) data to Supermetrics.
Before you can fetch data from X Organic data source connector, you need to subscribe to the Premium package in X which gives you access to advanced analytics.
In addition to the Premium package, you must have the following to fetch X Organic data:
A completed X profile
An active X Ads account connected to the X profile. Follow these steps to create a X Ads account.
Next, you will need access to the Ad account linked to the X account you want to report data for:
Open the X Ads portal.
In the top right-hand corner, click your account name and select Edit access to account.
If you don't yet have access to this Ad account:
Click Add access, and add your handle.
Select Ad manager or Account administrator role.
Check the box for Can compose promotable Tweets under the role selection.
Click Save changes.
If you already have your account added:
Make sure you have Ad manager or Account administrator role and the option to compose promotable tweets.
If not, click Edit access.
Change the role.
Check the box for Can compose promotable Tweets.
Click Save changes.
Access posts from other X profiles
To fetch posts for another X account with multi-user login, you must be added as a Campaign analyst or Administrator to the other X Ads account.
Please ask the administrator of the other X account to do the following:
Create an X ad account if they don’t have one already. Follow these steps to create an X Ads account.
Navigate to X Ads.
Click the account name in the top right corner and select Edit access to account.
Click Add access.
Enter the name of your X handle in the text box, select Campaign analyst or Administrator.
Check the box for Can compose promotable Tweets next to your account.
Save the changes.
Profile info: Get X profile-level metrics.
Tweet engagement: Measure the organic performance of your posts.
When connecting to X Organic (Twitter), you need to log in to X and select the account to pull data from.
Select the X Organic (Twitter) data source on the Supermetrics Hub or in the data destination.
Log in to the X account you want to fetch data from.
Click Authorize app to allow the Supermetrics app to access your profile data.
In your data destination, select the account to include in your reporting and a query type.
You can also connect to X Organic (Twitter) from these destinations:
AI tools and dashboards:
