WooCommerce connection guide
This guide contains all permissions and requirements for connecting your WooCommerce data to Supermetrics.
To pull data from WooCommerce, the Analytics section must be enabled in your web store on the WooCommerce side. A role of Shop Manager or higher is required.
To connect Supermetrics to your WooCommerce store, you'll need a consumer key, consumer secret, and store URL.
  • The key and secret can be obtained from WooCommerce. Go to WooCommerce → Settings → Advanced → REST API. WooCommerce's documentation has detailed steps to get the key and secret.Note that prior to WooCommerce version 3.4, the key generation was located at WooCommerce → Settings → API → Key/Apps.
  • The store URL can be obtained from the address bar when you log in to Wordpress. The store URL must include https:// at the beginning. Copy only the first part of the address, for example https://example.com, and leave out the rest of the URL.
  • Sales overview: Report the overall sales for the store.
  • Sales by product: Fetch key sales metrics by product.
  • Orders: Fetch details of orders for your store in a certain time range.
  • Order items report: Fetch detailed data of all the order items sold in a certain time range.
    Note
    The Orders and Order items report are not currently available in the Data Studio destination.
When connecting to WooCommerce, you need to enter your consumer key, consumer secret, and store URL and select a store and query type when prompted.
  1. Select the WooCommerce data source on the Supermetrics Hub or in the data destination.
  2. Insert your consumer key, consumer secret, and store URL.
  4. Click Start.
  5. In your data destination, select a store to fetch data for and query type to use.
You can also connect to WooCommerce from these destinations:
More information
