Tradedoubler connection guide
This guide contains all permissions and requirements for connecting your Tradedoubler data to Supermetrics.
To connect Supermetrics to your Tradedoubler account, you need to create an API client and client secret.
Note that only account owners can generate new API clients in Tradedoubler. Please contact Tradedoubler if you're not sure who the account owner is.
Create a Tradedoubler API client
  1. Log in to the Tradedoubler API Client UI.
  2. Create a client which provides a client ID and client secret. Note that the client secret is only shown once. Copy the client secret and keep it safe.
  • Program: Get aggregate performance metrics, such as impressions and clicks, per affiliate program.
  • Affiliate: Get aggregate performance metrics, such as impressions and clicks, per affiliate affiliate site.
  • Ad: Get aggregate performance metrics, such as impressions and clicks, per individual ad.
When connecting to Tradedoubler, you need to provide your Tradedoubler credentials.
  1. Select the Tradedoubler data source on the Supermetrics Hub or in the data destination.
  2. Enter your Tradedoubler username, password, client ID, and client secret.
  3. Give your account a name to recognize the login later if you have multiple logins.
  5. Click Start.
  6. In your data destination, select a query type when prompted.
You can also connect to Tradedoubler from these destinations:
