StackAdapt connection guide
This guide contains all permissions and requirements for connecting your StackAdapt data to Supermetrics.
You'll need an API key to give Supermetrics permission to pull your data. Contact your StackAdapt account manager to create this key.
When connecting to StackAdapt, you need to provide your API key and select the accounts to pull data from.
  1. Select the StackAdapt data source on the Supermetrics Hub or in the data destination.
  2. Enter your API key.
  4. Click Start.
  5. In your data destination, select the account to use in your reporting.
You can also connect to StackAdapt from these destinations:
