This guide contains all permissions and requirements for connecting your Simplesat data to Supermetrics.
To connect Supermetrics to Simplesat, you need:
Your account/API key, which you can find on the Account settings page in your Simplesat account. Read Simplesat's documentation to learn how to find your account/API key.
Answers: Get answers to feedback survey questions
When connecting to Simplesat, you need to provide your account key.
Select the Simplesat data source on the Supermetrics Hub or in the data destination.
Enter your Simplesat account key.
In your data destination, select a query type to use, if prompted.
You can also connect to Simplesat from these destinations:
