Shopee Commerce connection guide
This guide contains all permissions and requirements for connecting your Shopee Commerce data to Supermetrics.
To pull commerce data from Shopee using Supermetrics, you need a Shopee account.
In addition:
  • You must authenticate using a normal Shop account. Main accounts and sub-accounts are not compatible with the connector.
  • You need the email/phone number/user name and password of the Shop account.
Learn more about different types of Shopee accounts.
  • Orders: Retrieve detailed insights about your shop orders.
  • Order Items: Retrieve detailed insights about products ordered from your shop.
When connecting to Shopee Commerce, you need to Shopee Commerce and select the shop region when prompted.
  1. Select the Shopee Commerce data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Select your store region from the dropdown and insert your email/phone number/user name and password.
  5. Confirm the authorization for Supermetrics to access your Shopee data.
  6. In your data destination, account to pull data from and a query type, if prompted.
You can also connect to Shopee Commerce from these destinations:
