Semrush Projects connection guide
This guide contains all permissions and requirements for connecting your Semrush Projects data to Supermetrics.
To connect Supermetrics to Semrush Projects, you need an API account, an API key, and a Semrush subscription for API request units. Learn more about Semrush accounts and API request units.
Set up your Semrush Project queries using any of the query types described below.
Reference list: Semrush Projects query types
  • Position tracking
    • Campaign dates
    • Organic overview
    • Organic positions report
    • Adwords positions report
    • Organic competitors discovery report
    • Adwords competitors discovery report
    • Organic visibility index report
    • Adwords visibility index report
  • Site audit
    • Get a list of a campaign's snapshots
    • Get text descriptions about issues
    • Get information about a campaign
    • Get information about a snapshot
    • Detailed report for an issue
    • Get page ID by an URL
    • Get information about a page
    • Get snapshots history
When connecting to Semrush Projects, you need to provide your API key and select the project to use when prompted.
  1. Select the Semrush Projects data source on the Supermetrics Hub or in the data destination.
  2. Enter your API key.
  4. Click Start.
  5. In your data destination, select a project to include in your report and a query type.
You can also connect to Semrush Projects from these destinations:
