Recharge connection guide
This guide contains all permissions and requirements for connecting your Recharge data to Supermetrics.
Before using the Recharge connector, you need to generate an API token for authentication in the Recharge merchant portal.
By default, only storeowners can view and access API tokens. Storeowners can update account permissions to allow additional staff accounts access to the API Tokens page.
To create a new API key:
  1. Login to the Recharge merchant portal.
  2. Navigate to Tools & apps and click API tokens.
  3. On the following page, click Create an API Token to generate a new token for your store.
  4. Use the Details fields to set a name and contact email for the token.
  5. Select No access, Read access, or Read and Write access to set the scope permissions you'd like to grant the token.Required scopes: read_store, read_orders, read_subscriptions
  6. Click Save to create your token.
  • Orders: Fetch data of all the orders made in your Recharge account.
  • Order items: Fetch data about all the order items sold in your Recharge account.
  • Charges: Fetch data about all the charges made in your Recharge account.
  • Subscriptions: Fetch data about all the subscriptions in your Recharge account.
When connecting to Recharge, you need to provide your API credentials.
  1. Select the Recharge data source on the Supermetrics Hub or in the data destination.
  3. Enter the API credentials.
  4. Click Start.
  5. In your data destination, select the query type to use in your reporting.
You can also connect to Recharge from these destinations:
