This guide contains all permissions and requirements for connecting your Readpeak data to Supermetrics.
To connect to Readpeak, you need:
A Readpeak account with the Administrator, Producer, or Manager user role to connect
A copy of the account's API key
Set your account role
Log in to Readpeak.
In the top right corner, click Settings.
Open the Profile tab.
Check your account's user role under Role. If you don't have the right permissions, get in touch with your administrator for help.
Get your API key
Navigate to the top left corner. You'll find your key under Your API Key.
Be sure to keep your API key safe and secure, as it gives access to all of your account's data.
Campaigns report: Fetches all the basic ad performance metrics for your ad campaigns
When connecting to Readpeak, you need to provide your API key.
Select the Readpeak data source on the Supermetrics Hub or in the data destination.
Enter your API key.
Give your login a name to recognize the login later if you have multiple logins.
In your data destination, select the accounts to pull data from and a query type, if prompted.
You can also connect to Readpeak from these destinations:
