Plausible connection guide
This guide contains all permissions and requirements for connecting your Plausible data to Supermetrics.
Before using the Plausible connector, you’ll need to generate an API key for your plausible account.
How to create an API Key
  1. Log in to your Plausible account.
  2. Open the API keys page.
  3. Click New API Key to generate a new API key. You can use either the Stats API or Sites API key type.
  4. The API Key will be shown only once. Copy it to a secure location for later use.
  • Stats: View historical and real-time stats for your website.
When connecting to Plausible, you need to enter your API Key and select the query type if prompted.
  1. Select the Plausible data source on the Supermetrics Hub or in the data destination.
  2. Enter your Plausible API Key and give a name for your login.
  4. Click Start.
  5. In your data destination, select the account to pull data from and a query type, prompted.
You can also connect to Plausible from these destinations:
