This guide contains all permissions and requirements for connecting your Piwik PRO data to Supermetrics.
To connect to Piwik PRO, you'll need copies of your account name, client ID, and client secret.
Get your account name
Log in to your Piwik PRO dashboard.
Your account name is the first part of the URL you see in your browser's address bar.
For example, if your URL is
exampleABC.piwik.pro, then your account name isexampleABC.
Get your client ID and client secret
Click Menu in the top left.
Select Profile from the dropdown.
Select the API Keys tab on the left.
Click Create key.
Give your key a memorable name.
Copy the client ID and client secret. Keep them in a secure, safe place.
Analytics: Fetch website and product analytics data from Piwik PRO's Analytics product.
When connecting to Piwik PRO, you need to provide your credentials and select the account to use.
Select the Piwik PRO data source on the Supermetrics Hub or in the data destination.
Enter your account name, client ID, and client secret.
In your data destination, select the accounts to include in your reporting and a query type, if prompted.
You can also connect to Piwik PRO from these destinations:
