Partnerize connection guide
This guide contains all permissions and requirements for connecting your Partnerize data to Supermetrics.
Before using the Partnerize connector, you need a copy of your Application Key and API Key.
Get your application key and API key
  1. Log in to your account on the Partnerize console.
  2. In the Partnerize console, click your account name in the top left.
  3. From the drop-down list, select Account settings.
  4. On the left hand side, click the eye icons next to Application Key and API Key to reveal them.
  5. Copy the application key and API key to a safe place.
Query types define what sort of metrics and dimensions are available. Supermetrics supports 3 Partnerize report types to fetch performance data of your partnerships. You need to select one of the following query types when pulling data:
  • Impression report
  • Click report
  • Conversion report
When connecting to Partnerize, you need to provide your application key and API key.
  1. Select the Partnerize data source on the Supermetrics Hub or in the data destination.
  2. Enter your application key and API key.
  3. Give your login a name to recognize the login later if you have multiple logins.
  5. Click Start.
  6. In your data destination, select the accounts to pull data from and a query type.
You can also connect to Partnerize from these destinations:
