Odoo CRM connection guide
This guide contains all permissions and requirements for connecting your Odoo CRM data to Supermetrics.
You will need an API key and your database name in order to connect to Odoo CRM.
How to create an API key
  1. Log in to your Odoo account.
  2. Select your database and the CRM module.
  3. In the top-right corner, click on your user profile picture and select Preferences.
  4. Select the Security tab.
  5. In the API Keys section, click Add API key.
  6. Enter your password to confirm your identity.
  7. Give a name to your key (for example, “Supermetrics”) and define how long the key will be valid. If the key expires, you will need to create a new one.
  8. Click on Generate key.
  9. The API key will now be shown once; copy it to a secure location for later use.
Full instructions to create an API key are available in Odoo’s documentation.
How to find your database name
  2. The database name is visible on the left side.
  • Leads: Retrieve detailed insights about your Odoo leads data.
  1. Select the Odoo CRM data source on the Supermetrics Hub or in the data destination.
  2. Enter the API key and database name.
  4. Click Start.
  5. In your data destination, select the ad accounts to include in your reporting and a query type, if prompted.
You can also connect to Odoo CRM from these destinations:
