This guide contains all permissions and requirements for connecting your Nielsen Digital Ad Ratings data to Supermetrics.
Before using the Nielsen Digital Ad Ratings connector, you need to have a client ID and a client secret to access the Nielsen DAR API.
To get these credentials, reach out to your Nielsen Digital Ad Ratings representative and ask them to create and share the credentials with you.
Audience profile: Pull lifetime campaign data split by demographic groups
Site: Pull lifetime campaign data split by sites
Platform: Pull lifetime campaign data split by platforms
Population: Pull the Population base for each demo segment in order to calculate population share metrics, such as Audience reach.
When connecting to Nielsen Digital Ad Ratings, you need to provide your client ID and client secret.
Select the Nielsen Digital Ad Ratings data source on the Supermetrics Hub or in the data destination.
Enter your Nielsen email address and password.
Enter your client ID and client secret.
In your data destination, select the campaigns to include in your reporting and a query type to use.
You can also connect to Nielsen Digital Ad Ratings from these destinations:
