This guide contains all permissions and requirements for connecting your Nexxen DSP data to Supermetrics.
Before using the Nexxen DSP data source connector, you need your Nexxen DSP client ID and client secret, as well as appropriate permissions for data access on your account. Follow the instructions in Nexxen DSP's API documentation to generate the credentials.
To pull reporting data, you need to have access to Reporting API.
Performance: Build reports with your performance data
When connecting to Nexxen DSP, you need to provide your credentials.
Select the Nexxen DSP data source on the Supermetrics Hub or in the data destination.
Enter your client ID and client secret.
You can also connect to Nexxen DSP from these destinations:
