Microsoft Advertising connection guide
This guide contains all permissions and requirements for connecting your Microsoft Advertising data to Supermetrics.
To connect Supermetrics to Microsoft Advertising, you need:
Note that you need to connect with your Microsoft personal or work account. A Google account used to sign in to Microsoft Ads isn’t compatible with the Supermetrics authentication flow.
See our Microsoft Advertising permissions troubleshooting guide if you're experiencing issues with permissions in your organization or need admin approval.
When connecting to Microsoft Advertising, you need to log in to Microsoft and select the accounts to pull data from.
  1. Select the Microsoft Advertising data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Enter your Microsoft email address and click Next.
  5. Enter your Microsoft password and click Sign in.
  6. Click Accept.
  7. In your data destination, select the accounts you'd like to include in your reporting.
You can also connect to Microsoft Advertising from these destinations:
