LINE Ads connection guide
This guide contains all permissions and requirements for connecting your LINE Ads data to Supermetrics.
Before using the LINE Ads data source connector, API access must be enabled for the relevant Group on your LINE Ads account. Please contact your LINE account manager to enable this.
Once API access is enabled, you need a copy of the group ID, access key, and secret key of the group you want to connect to.
Get your group ID
  1. Log in to the LINE Ad Manager.
  2. Navigate to the Groups page.
  3. The group ID is shown in the table next to the group name, in the format “G123456789”.
Get your access key and secret key
  3. Select the group you want to fetch data for.
  4. Click Menu in the top left corner.
  5. Under Settings, click Group settings.
  6. Copy the API access key and API secret key to a safe place. If you cannot see the secret key, click Regenerate your API secret key.
  • Campaign performance: Get aggregated performance data on campaign, ad group and ad level.
When connecting to LINE Ads, you need to provide your LINE Ads credentials.
  1. Select the LINE Ads data source on the Supermetrics Hub or in the data destination.
  3. Enter your group ID, access key, and secret key.
  4. Give your login a name so that you can recognize the login later if you have multiple logins.
  5. Click Start.
  6. In your data destination, select a query type, if prompted.
You can also connect to LINE Ads from these destinations:
