This guide contains all permissions and requirements for connecting your IQM data to Supermetrics.
You'll need an IQM account with a username and password to connect.
Campaign performance: Measure the performance of the campaigns you manage with IQM.
When connecting to IQM, you need your IQM username and password.
Select the IQM data source on the Supermetrics Hub or in the data destination.
Enter your IQM username and password.
In your data destination, select the timezone and query type to use, if prompted.
You can also connect to IQM from these destinations:
AI tools and dashboards:
