Indeed Reviews connection guide
This guide contains all permissions and requirements for connecting your Indeed Reviews data to Supermetrics.
To connect Indeed Reviews data to Supermetrics, you need a business' Indeed Company ID. You don't need an account or login.
To find an Indeed Company ID:
  1. Open the business' Indeed page.
  2. Copy the string after /cmp/in the URL.
    • For example, a business called Example Business would have a URL ending in /cmp/example-business. Here, the Company ID is example-business.
When connecting to Indeed Reviews, you need to enter the Indeed Company IDs to query.
  1. Select the Indeed Reviews data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. In your data destination, enter the Indeed Company ID in the Company name field.
You can also connect to Indeed Reviews from these destinations:
