Google PageSpeed Insights connection guide
This guide contains all permissions and requirements for connecting your Google PageSpeed Insights data to Supermetrics.
The Google PageSpeed Insights data source connector doesn't require you to log in to a specific account.
  • PageSpeed Insights
When connecting to Google PageSpeed Insights, you need to enter at least one URL to query.
  1. Select the Google PageSpeed Insights data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. In your data destination, enter one web page URL to query and select the device type (desktop or mobile). Make sure to include also the http:// or https:// part of the URL.
You can also connect to Google PageSpeed Insights from these destinations:
