G2 Reviews connection guide
This guide contains all permissions and requirements for connecting your G2 Reviews data to Supermetrics.
You can query data from G2 Reviews without logging in to G2.
To pull data on a product or service on G2 Reviews, you'll need to copy the identifier from its G2 Reviews URL.
For example, if the G2 Reviews URL is g2.com/products/example/reviews, its company ID is example.
  • Reviews: Fetch up to 250 of the latest public reviews for a product or service.
When connecting to G2 Reviews, you need to enter the software or service names to query.
  1. Select the G2 Reviews data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. In your data destination, select a query type, if prompted, and enter the software or service name to include in your report.
You can also connect to G2 Reviews from these destinations:
