Facebook Billing Data connection guide
This guide contains all permissions and requirements for connecting your Facebook Billing Data data to Supermetrics.
To connect Supermetrics to Facebook Billing Data, you need the Finance Editor access level. Learn more about Facebook Business Manager permissions.
You also need to have monthly invoicing enabled for your Facebook Business Manager account to get its invoice data. Supermetrics can't pull data on transactions that aren't part of a monthly billing cycle. Learn more about monthly invoicing.
You can query your lists of invoices and invoicing amounts, as well as rich metadata, campaign, and performance data for each invoice.
When connecting to Facebook Billing Data, you need to log in to Facebook and select the accounts to pull data from when prompted.
  1. Select the Facebook Billing Data data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Either log in with a new Facebook account, or click Continue as to go ahead with the account you're already logged in to.
  5. Select the Businesses you want to include in your reporting.
  6. Review the permissions, and click Save.
  7. Click Got it.
  8. In your data destination, select the accounts you'd like to include in your reporting.
You can also connect to Facebook Billing Data from these destinations:
