Eloqua connection guide
This guide contains all permissions and requirements for connecting your Eloqua data to Supermetrics.
You will need your Eloqua username, password, and site name to connect to Eloqua.
The site name can be found in your Eloqua account by clicking on the top right account box and then copying the site name underneath your account name.
Query types define which metrics and dimensions are available. You need to select one of the following query types when pulling data:
  • Campaign analysis: Retrieve insights on your Eloqua campaigns.
  • Campaign form submissions: Retrieve insights on your Eloqua form submissions on a campaign level.
When connecting to Eloqua, you need to enter your username, password, and site name.
  1. Select the Eloqua data source on the Supermetrics Hub or in the data destination.
  2. Enter your Eloqua username, password, and site name.
  4. Click Start.
  5. In your data destination, select the account to pull data from and a query type, if prompted.
You can also connect to Eloqua from these destinations:
