Ecwid connection guide
This guide contains all permissions and requirements for connecting your Ecwid data to Supermetrics.
You will need your Store ID and Secret app token to connect to Ecwid.
How to retrieve your Store ID
  • Go to the admin dashboard of your Ecwid store.
  • The Store ID is visible in the footer section of every page.
  • It’s also included in the URL of the web page, for example, “https://my.ecwid.com/store/1234567“ where 1234567 is the Store ID.
How to create your Secret app token
  • Go to the app dashboard of your Ecwid store.
  • Click Create, next to “Add new app”.
  • On the app detail page, click Show secret token.
  • Copy the secret token to a secure place for use later.
  • Orders: Fetch data of all the orders made in a certain time range.
When connecting to Ecwid, you need to enter your Store ID and Secret app token.
  1. Select the Ecwid data source on the Supermetrics Hub or in the data destination.
  2. Insert your Store ID and Secret app token.
  4. Click Start.
  5. In your data destination, choose your desired store(s), date range metrics, and dimensions. For Query options settings, select “Fetch orders by created or updated date.”
You can also connect to Ecwid from these destinations:
