Clockify report building guide
Use the Clockify connector to track time spent on different tasks by reporting all time entries added to Clockify. Fetch data by time, user, client, or project, and see the effective billing rate across your employees and projects.
Popular queries
These query configurations help you track key performance indicators and analyze trends. You can use these settings in any Supermetrics destination, such as Data Explorer, Dashboards, Google Sheets, Data Studio, or data warehouse destinations.
Review time entries from last week
Get a daily view of how time was logged last week, so you can review workload distribution and identify any gaps in time tracking.
Setting
Value
Date range
Last week
Metrics
Duration (h)
Dimensions
Entry start date
Suggested visualization
Table
Understanding the data
  • Duration (h): The duration of the time entry in hours.
  • Entry start date: The date the time entry started, used to split results by day.
Compare billable hours and amounts month over month
See last month's total logged hours and billable amounts side by side with the previous month, so you can track trends in billing and resource utilization.
Setting
Value
Date range
Last month
Date range comparison
Previous period
Metrics
Amount, Duration (h)
Table
  • Amount: The rounded value of the billable amount for the time entry.
Break down billable hours by project and task
See billable amounts and total hours for the current month split by task description and task ID, giving you a detailed view of where time and budget are being spent across projects.
Setting
Value
Date range
This month to date
Metrics
Dimensions
Description, Task ID
Table
  • Description: The description of the time entry, typically used to note what work was done.
  • Task ID: The unique identifier of the task the time entry is logged against, useful for linking entries to specific project tasks.
