Capterra Reviews connection guide
This guide contains all permissions and requirements for connecting your Capterra Reviews data to Supermetrics.
To connect Supermetrics to Capterra Reviews, you need a Capterra product identifier for search. This identifier can be taken from the URL of the product page in Capterra.
For example, if the product URL in Capterra is capterra[dot] com/p/135003/Slack, the identifier is 135003.
  • Reviews: Get data on reviewers, review title, rating, text, pros, cons, and dates with the number of reviews and average ratings.
When connecting to Capterra Reviews, you need to enter the software IDs to query.
  1. Select the Capterra Reviews data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. In your data destination, select the query type, if prompted, and enter the software IDs to include in your query.
You can also connect to Capterra Reviews from these destinations:
