BigCommerce connection guide
This guide contains all permissions and requirements for connecting your BigCommerce data to Supermetrics.
To pull data from BigCommerce using Supermetrics, you need a BigCommerce account.
In addition, you need:
  • Your BigCommerce store hash. The store hash is in the URL of your BigCommerce shop (usually comes right after the https://store-).
  • A BigCommerce API token. This can be created in BigCommerce under Settings → API → Store-level API accounts.
  • Orders: Retrieve detailed insights on your BigCommerce shop orders.
  • Order Items: Retrieve detailed insights on your Bigcommerce ordered products.
When connecting to BigCommerce, you need to provide your BigCommerce store hash and API token and select the account to use when prompted.
  1. Select the BigCommerce data source on the Supermetrics Hub or in the data destination.
  2. Enter your store hash.
  3. Enter your BigCommerce API token.
  4. Give a name for your login.
  6. Click Start.
  7. In your data destination, select the account to pull data from and a query type, if prompted.
You can also connect to BigCommerce from these destinations:
