Best practices for Data Studio
Data Studio (formerly Looker Studio) offers many useful features that you can use to enhance your Supermetrics reports.
Additionally, if you need to solve issues or optimize Data Studio itself, Google's comprehensive troubleshooting documentation can help.
Background
This guide includes a collection of Data Studio features that you might find useful, especially for building advanced reports.
Please note that these features are built-in Data Studio functionalities, so Supermetrics support can only offer limited assistance. You can learn more and find troubleshooting help in the Data Studio help center.
Features and best practices
Data freshness
The data freshness setting has no effect on Supermetrics connectors in Data Studio. The Supermetrics connectors refresh the data when you do something that triggers the retrieval of data. Such as:
  • Refresh the report
  • Load the report page
  • Add or update elements on the report
Data blending
The data blending feature can be used to connect and blend data from several data sources. Using join keys, data from several sources can be used in the same chart. See our guide to learn more about data blending in Data Studio.
Alternatively, with Supermetrics, you can create blends of your Supermetrics data sources, configure blended fields in one view, and use the blended data directly in your reports. Learn more about Supermetrics data blending.
Calculated fields
Calculated fields let you create new metrics and dimensions derived from your data. There are 2 types of calculated fields in Data Studio: data source and chart-specific fields.
They each have different advantages and limitations. See the Data Studio help center to learn more about calculated fields.
Calculations using basic operations
In a calculated field, you can perform any arithmetic calculations: addition (+), subtraction (-), division (/), and multiplication (*).
Calculations using functions
In addition to basic operations, Data Studio provides a list of functions for calculated fields. See the Data Studio help center for a full list of functions.
For example, using the Case function you can define conditions to categorize or group your data. In the example below, we only want to show two categories: Paid and Other. The Paid group will contain the medium "cpc" while the Other group will contain all other mediums.
Formula for categorizing mediums into paid and other user groups displayed in a table.
If you run into error messages in your calculation, you may be applying incorrect functions to the original fields. See the Data Studio help center for assistance with troubleshooting calculated fields.
You can also use Supermetrics custom fields to create your own custom metrics and dimensions, or create calculated fields. See our documentation on Supermetrics Custom Fields to learn more.
Filters
With filters, you can refine or reduce the data shown in your report based on defined conditions. You can apply filters to a specific chart, control, page, or the whole report. To get started with filters, please refer to our guide on using filters and the Data Studio help center.
Filter controls
In addition to chart-specific filters that can only be set by report editors, people with Viewer access can also change filter conditions to narrow down results. See the Data Studio help center for more information and a full list of available filter controls.
For example, with an Advanced filter, viewers can select a search operator and input a specific value for filtering the data.
Table displaying campaign names and their corresponding impressions for TOFU 2021.
Extract Data
Data Studio has a 6-minute limit on handling queries, and large data requests might cause your report to load slowly or time out. With the Extract Data connector by Google, you can explore a subset of your data and improve the speed and performance of your report, or build reports for certain cohorts of data. Learn more in our blog.
Subset with selected fields
By default, data sources are created with a full list of their supported dimensions and metrics, some of which you may not need. Using the Extract Data connector, you can handpick the dimensions and metrics that are meaningful for your reports.
Subset with a filter or date range
In the Extract Data connector settings, you can define a subset of data based on a filter condition or date range.
For example, if your campaigns are targeted at multiple locations, you can use a filter to define that "Country" is equal to the location of your choice, filtering the whole subset of data to that country. In the date range section, you can limit the dataset to a preset time frame or set custom start and end dates for your subset of data.
Supermetrics Storage
Supermetrics Storage is designed to handle large amounts of data. It’s especially useful when your Data Studio reports are slowing down or even crashing due to longer load times from the data source APIs. You can learn more about Supermetrics Storage in the Supermetrics blog.
Tips and tricks for building charts
Decimal precision
When reporting on data in a number format, you may want to display fewer or more decimal places. You can adjust the decimal precision of a chart in the STYLE tab Metrics section.
Table displaying dates and corresponding costs for various entries in June 2021.
Set the range by data
When working with a time series chart, the data from your selected date range may be squeezed in the middle of a chart that displays a longer time period. You can adjust the chart axis in the STYLE tab X-Axis section by selecting the Range by Data setting.
Graph showing reach over weeks with highlighted range settings for data analysis.
Comparison metrics and running calculations
In Data Studio, you can compare your data to total and running values. You can access the comparisons and running calculations as you edit a metric. See the Data Studio help center to learn more about adding comparison metrics and running totals.
For example, you can use the Running delta option to calculate the difference between the current row and the previous row for a view of increasing or decreasing values.
Data table showing daily spending and differences with calculation options on the right.
Account selector control
In Data Studio, you can use the account selector control to view data from particular data source accounts only.
To add the account selector control:
  1. Select all ad accounts you want users to see and pull data from when setting up the data source or editing the data source connection.
  2. On your dashboard, click Add control.
  3. Select Drop-down list.
  4. Make sure the right data source is selected to filter the accounts for.
  5. In the Control field selection, select Account name to use the account name as the filtering criterion.
Note that you can add only one account selector per page. Multiple account selectors for different data sources on one page will break the dashboard and result in the This data source was improperly configured error. To avoid the error, create dashboards with one data source and one account selector per page.
