Basis connection guide
This guide contains all permissions and requirements for connecting your Basis data to Supermetrics.
To connect Supermetrics to your Basis account, youll need your Basis username and password.
  • Campaign performance: Get campaign performance data
  • Creative performance: Get creatives performance data
When connecting to Basis, you need to log in to Basis and select the accounts to pull data from when prompted.
  1. Select the Basis data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Log in to Basis.
  5. Click Authorize to allow Supermetrics to access your data.
  6. In your data destination, select the accounts to use and a query type, if prompted.
You can also connect to Basis from these destinations:
