Power BI
This section of the knowledge base covers everything you need to know about using Supermetrics to power your data in Power BI.
Use these articles as a reference when you're getting started with Supermetrics in Power BI, want to work smarter, or experience any issues with your reports.
You'll learn, for example, how to use our report templates and how to set up scheduled refreshes for your data.
Get started with Power BI
Follow these steps to get started:
  1. First, register a Supermetrics account by logging in to the Supermetrics Hub with your Microsoft or Google account using this link. If you have a Supermetrics account already, simply log in to the Hub.
  2. Now, you're ready to create your first query on the Supermetrics Hub! Your trial starts when you create your first query. Take a look at our data source connection guides for the details you need to connect.
  3. Then, launch the Supermetrics connector for Power BI. If you can't find the Supermetrics connector, check that you're running the latest version of Power BI Desktop.
  4. Finally, you can load your data to Power BI.
The following video highlights the main steps for getting started with Supermetrics for Power BI.
Learn more
Take a look at how to set a schedule for data refreshes, and explore the articles on using Supermetrics for Power BI.
To get the most out of your data sources, take a look at our data source guides, including report building guides.
Report templates
We have a wide range of report templates available for Power BI. You can find all templates in our template gallery.
In case something doesn't go as expected, take a look at our troubleshooting articles for Power BI.
If you're having issues with a data source, check out the reauthentication guide and articles related to the data source.
Contact our support team if you can't find an answer to solve your issue.
Happy reporting!
