If something’s gone wrong with your team or subscription's registration, you might encounter one of these error messages:
Your trial has expired. Purchase a subscription at https://hub.supermetrics.com/subscription/purchaseYour subscription has expired. Renew your subscription at https://hub.supermetrics.com/subscriptions
Follow these steps if you see these errors in Data Studio (formerly Looker Studio).
Verify that your subscription is active and assigned to you.
Make sure that you use the user account assigned to the subscription when you reauthenticate the data source. Make sure that you're in the correct team and have a valid subscription.
Remove all unused data source connections — follow these instructions.
If you belong to multiple teams and the issue persists, we highly recommend merging the teams.
Contact our support team for help if this error persists, or if you have any questions about it.
