Replacing a “null” value with a 0 makes it easier to use math functions in the Data Studio (formerly Looker Studio) reports you build with Supermetrics.
You can also convert values to cosmetic zero, if you want to change their appearance in your reports but don’t need to use them for functions.
Use the NARY_MAX or IFNULL functions to convert null to 0. Follow these steps to create a new field for the function.
Open your report in Data Studio.
Click any chart or table to open the SETUP tab.
Click the Metric field.
Click Add metric.
Enter the
NARY_MAX(<yourfieldname>,0)orIFNULL(<yourfieldname>,0)function in the Formula field.Click Apply.
Here’s a Google Ads example with the “Cost” metric.
Cosmetic zero
To convert a value to "0" for cosmetic reasons, you can use a Data Studio setting to style the results to any value that you want to represent “no results”.
Open your report and click the element you’d like to adjust. Navigate to the Style tab and scroll down to Missing data. Then, choose your preferred value from the dropdown.
If any value in the math is null, it will turn the whole result null when you’re using metrics to create custom calculations for your reports.
To solve this problem, you can create a new calculated field for each metric with the above formulas, and then use these fields instead to build your custom calculations. With the nulls as zeros, the math will be calculated correctly.
In some cases, especially with unique count metrics like Reach and Views, it might be that the report is trying to sum deduplicated values. If this is the case, follow these instructions to resolve the issue.
