Reference guide: Custom fields functions
Use these functions to create custom fields in Supermetrics.
Function name
Description
Absolute
Gets the absolute value from a selected field. For example, abs(10) and abs(-10) would both have 10 as their result.
Apply date format
Converts date values to the specified format.
Concatenate
Allows you to combine text strings or fields into one single field.
Convert data type
Converts data from one type into another, and returns a default result if the change isn't possible. Learn more about our supported data types.
For example, convert a date into text by entering the value "string" in the "Type" field.
Count occurrences
Count the number of times a character or piece of text occurs in a text.
Currency conversion
Convert value to specified currency using historical EOD currency rate.
Detect logos in images
Detects company and product logos in images. As input for this function, you must add a field that contains an image URL. AI transformation functions are available in all Marketing Intelligence Platform. Limits apply, read more here.
Divide
Divides a field by a certain value.
For example, use it to divide "Clicks" by any given number, or by another numeric field in your data source.
Extract string with regex
Replace field value with a regular expression match. "Pattern" defines a PCRE-compatible regular expression were looking for, and "Index" the regex group index that should be used. Defaults to "1" for the first available match.
Extract substring
Extract part of a text string based on the number of characters in the string. "Start" defines which character in the string will begin the extracted text, and "Length" defines how many characters will be included in the text.
For example, setting the start to 1 and length to 5 would turn the words "Black Friday" into "Black".
Find and replace string with regex
Find and replace strings from field with a regular expression. "Pattern" defines a PCRE-compatible regular expression we're looking for, and "Replace" what the match is replaced with.
Hash
Hash field with given algorithm. Empty strings are left intact.
Hash with key
Hash field with given algorithm and secret key. Empty strings are left intact.
Lower case
Converts any text to lowercase.
For example, using it on "Black Friday" would change the text to "black friday".
Multiply
Allows you to multiply the value for a field by a given number or the value from another field.
Replace empty values
Sets a fallback value for any fields that return no data.
For example, use it to fill in fields for nameless campaigns with something like "Unknown campaign".
Return bigger value of out two
Selects the greater value from two options.
For example, if you specify a value of 100 and select a field to compare that value that has a value of 150, this function will return 150.
Return smaller value out of two
Selects the lesser value from two options.
Round
Rounds numbers up or down to the next closest integer.
For example, using it on a value of 5.9 would result in 6, while a value of 5.1 would result in 5.
Round down
Rounds numbers down to the next lowest integer.
For example, using it on a value of 5.9 would result in 5.
Round up
Rounds numbers up to the next largest integer.
For example, using it on a value of 5.01 would result in 6, while using it on 5.0 would result in 5.
Split text and pick part
Splits a text string by a delimiter and returns one or more parts. Ideal for extracting a part of a campaign based on campaign taxonomy, for example.
Subtract
Subtracts a given number from a field, or use another field's values to subtract from it.
For example, use it to subtract 100 from all "Clicks", or to subtract "Costs" from "Revenue".
Sum
Sums up the values from a field with a given number or values from another field.
For example, use it to add "Taxes" to "Net Revenue" to form a "Gross Revenue" metric.
Trim
Strips whitespaces, tabs, and return carriage from the beginning and end of a field's values.
Upper case
Converts every letter in a text string to a capital letter.
For example, using it on "Black Friday" would convert the text to "BLACK FRIDAY".
Upper case first letter
Converts the first letter of a text string into a capital letter.
For example, using it on "black friday" would convert the text to "Black friday". In addition, with the "All Words" setting selected, "black friday" would be converted to "Black Friday", i.e. the first letter of all words in your string would be converted to upper case.
AI functions for custom fields
AI transformation functions are available for all users with Custom fields included in their Supermetrics subscription.
Read more about the usage limits for the AI transformations.
Function name
Description
Custom image analysis
Analyzes images. As input for this function, you must add a field that contains an image URL.
Detect landmarks in images
Detects landmarks in images. As input for this function, you must add a field that contains an image URL.
Image labelling
Labels can identify general objects, locations, activities, animal species, products, and more. As input for this function, you must add a field that contains an image URL.
Read text from images
Reads text from images using optical character recognition (OCR). As input for this function, you must add a field that contains an image URL.
Sentiment analysis
Categorizes text values in sentiments from very positive to very negative. Not that AI may produce inaccurate results.
Transform with AI prompt
Use LLM to enrich or transform your value using a prompt.
Translation
Translates text values in any language. Note that AI may produce inaccurate results.
