AppsFlyer report building guide
Use AppsFlyer to get data from different mobile applications. Gain insights into ad performance to understand how various campaigns contribute to app engagement and installs. Compare the performance of different apps to discover user interaction patterns and engagement.
To get the data you need, select the correct query type:
  • Aggregated performance (Pull API) report: Get basic aggregated performance data for your mobile apps. Available for all AppsFlyer users.
  • Aggregated geo performance (Pull API) report: Get performance data based on geographical location.
  • Aggregated performance (Master API) report: Fetch more granular data with less restrictive rate limits, including ad group, ad, and keyword splits. Requires a separate Master API subscription — contact AppsFlyer to gain access.
  • SKAN performance: Get campaign and installation performance data from Apple's systems.
  • Event data export: Fetch raw event-level data where each row is one event logged in AppsFlyer. Available only in data warehouse destinations and the Supermetrics API.
Popular queries
Analyze ad performance by campaign
See how different campaigns are driving app engagement and installs this month, so you can identify top performers and reallocate budget accordingly.
Setting
Value
Query type
Date range
This month
Metrics
Clicks, Impressions, Installs
Dimensions
Campaign name
Suggested visualization
Table
Understanding the data
  • Clicks: The number of times an ad was clicked over the selected date range.
  • Impressions: The total number of times an ad was displayed.
  • Installs: The number of new app installations successfully attributed to a specific campaign.
  • Campaign name: Splits results by campaign for side-by-side comparison.
Monitor user engagement across different apps
Track how actively users engage with each of your apps this quarter using daily and monthly active user metrics, helping you spot engagement trends and prioritize development efforts.
Setting
Value
Query type
Date range
This quarter
Metrics
Average daily active users (DAU), Average monthly active users (MAU)
Dimensions
App ID, App name
Table
  • Average daily active users (DAU): The average number of unique users who open the app on any given day within the reporting period.
  • Average monthly active users (MAU): The average number of unique users who open the app at least once within a calendar month.
  • App ID and App name: Splits results per app so you can compare engagement across your portfolio.
Note
This query requires the Master API, which is a separate subscription. Contact AppsFlyer to gain access.
Compare app installs and uninstalls over time
See the total number of installations and uninstallations month by month this year, so you can understand net app growth and identify periods of higher churn.
Setting
Value
Query type
Date range
This year to date
Metrics
Installs, Uninstalls
Dimensions
Year & month
Bar chart
  • Installs: The number of new app installations successfully attributed within the reporting period.
  • Uninstalls: The number of times the app was removed from a device within the reporting period.
  • Year & month: Splits results by month so you can track trends across the year.
Note
