--- title: "YouTube connection guide" slug: "youtube-connection-guide" description: "Connect your YouTube data to Supermetrics with our guide on permissions, query types, and connection instructions for seamless data integration." tags: ["Social media"] updated: 2026-07-17T10:01:51Z published: 2026-07-17T10:01:51Z canonical: "docs.supermetrics.com/youtube-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # YouTube connection guide This guide contains all permissions and requirements for connecting your YouTube data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/youtube-connection-guide#connection-instructions). If you're missing an account, skip to the [Missing accounts](/v1/docs/youtube-connection-guide#missing-accounts) section at the bottom of this page. ## Required permissions To connect YouTube to Supermetrics, you need these permissions: - Private accounts: **Owner** - Brand accounts: **Manager** Learn how to [find out which type of account you're using](https://support.google.com/youtube/answer/7286468) in Google's documentation. For most types of accounts and channels, the account logging in needs to be the channel's owner. Note that to pull monetization data, you need to be the **owner of the Content Manager account** or [your YouTube channel must have monetization enabled](/v1/docs/about-youtube-data-discrepancies-in-supermetrics). ## Query types Query types define what sort of metrics and dimensions are available. You need to select one of the following query types when pulling data: - **Videos performance**: Fetches engagement data per video, for up to 1000 of the most recently published videos on the selected channel. Splittable by date. - **Single video performance**: Fetches engagement data per specific video, defined with a video ID. Splittable by date. - **Channel overview**: Performance data for the channel, such as subscribers, likes, and average view duration. - **Geographies**: Breakdown of viewer engagement by country and state - **Demographic**: Breakdown of viewer percentage by age and gender - **Device**: Breakdown of viewer engagement by device type and operating system - **Traffic sources**: Breakdown of viewer engagement by traffic source - **Ad performance**: Gross revenue and ad impressions for your channel, broken down by ad type ## Connection instructions When connecting to YouTube, you need to log in to YouTube and select the channels to use when prompted. 1. Select the YouTube data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Sign in with Google**. 4. Log in with the Google Account you use with YouTube and select an account or brand account to use. 5. Click **Continue**, and click **Allow**. 6. Select all access scopes and click **Allow**. Failure to select all may result in the data source not functioning correctly. 7. In your data destination, select the query type to use and add the channel ID or video ID to include in your query. See detailed instructions on [how to connect to a data source from the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-connect-to-data-sources-from-supermetrics-hub). You can also connect to YouTube from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## Missing accounts If an account is missing from your available accounts in Supermetrics (including channels and videos), follow these steps: 1. [Create a new Google Account](https://support.google.com/accounts/answer/27441?hl=en). 2. [Log in to YouTube Creator Studio](https://www.youtube.com/account) with your original Google Account. 3. Navigate to **Settings** and then **Permissions** in the left-side menu. 4. Click **Invite** in the top right. 5. Add the new Google Account as the new user. 6. Create the new user as a **Manager** (if you're using a brand channel, **Owner** would also work). Click **Invite**. 7. Open the invitation email while logged in as the new user. Click **Visit the sign-up page to accept the invitation.** 8. Select **Use existing Google Account.** 9. Go back to the Supermetrics sidebar, and click **Add connection**. ## Disconnecting YouTube and Supermetrics If you want to disconnect your Google account used to access the Supermetrics YouTube data source connectors, follow these steps: 1. Go to [your linked apps in your Google Account](https://myaccount.google.com/connections?filters=3,4&hl=en). 2. In the list of apps, click the Supermetrics app with the round icon (there may be several different Supermetrics apps linked). 3. Under **Supermetrics has some access to your Google Account**, click **See details**. 4. Click **Remove all access**. > [!WARNING] > Warning > > Other Google data sources (such as Google Ads and Google Analytics) use this same app, so removing access will disconnect more than just your YouTube connection. If you wish to continue to use other Google data sources Supermetrics provides, you will need to reconnect each of those data sources again to continue service. ## More information - [YouTube report building guide](/v1/docs/youtube-report-building-guide) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
