--- title: "Yandex.Direct connection guide" slug: "yandexdirect-connection-guide" description: "Connect your Yandex.Direct data to Supermetrics with our guide. Learn about permissions and connection instructions for seamless data integration." updated: 2026-07-08T11:55:44Z published: 2026-07-08T11:55:44Z canonical: "docs.supermetrics.com/yandexdirect-connection-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://docs.supermetrics.com/llms.txt > Use this file to discover all available pages before exploring further. # Yandex.Direct connection guide This guide contains all permissions and requirements for connecting your Yandex.Direct data to Supermetrics. You can connect to data sources from the [Data sources page on the Supermetrics Hub](https://hub.supermetrics.com/token-management). On the Hub, you can also [share an authentication link](https://docs.supermetrics.com/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub#share-authentication-link) to connect to a data source you don't have direct access to. After you connect to the data source on the Hub, you can use the data source connection in [all available destinations](/docs/yandexdirect-connection-guide#connection-instructions). ## Required permissions To connect Yandex data sources, you need **Chief Representative** or **Representative** user access. [Learn more about Yandex user roles](https://yandex.com/dev/direct/doc/en/objects/roles). ## Connection instructions When connecting to Yandex.Direct you need to log in to Yandex. 1. Select the Yandex.Direct data source [on the Supermetrics Hub](https://hub.supermetrics.com/token-management) or in the data destination. 2. If prompted, choose to make this connection [shared or private](/v1/docs/about-shared-and-private-connections). 3. Click **Start**. 4. Enter your credentials, and click **Log in**. 5. Click **Allow**. See detailed instructions on [how to connect to a data source from the Supermetrics Hub.](/v1/docs/how-to-connect-to-data-sources-from-supermetrics-hub) You can also connect to Yandex.Direct from these destinations: - Google Sheets: [How to connect to a Supermetrics data source in Google Sheets](https://docs.supermetrics.com/docs/how-to-connect-to-a-supermetrics-data-source-in-google-sheets) - Data Studio: [How to connect data sources to Data Studio](/v1/docs/how-to-connect-data-sources-to-data-studio) - Excel: [How to connect data sources to Excel with Supermetrics](https://docs.supermetrics.com/docs/how-to-connect-data-sources-to-excel-with-supermetrics) - Power BI: [How to create your first Supermetrics query for Power BI](https://docs.supermetrics.com/docs/how-to-create-your-first-supermetrics-query-for-power-bi) - The Supermetrics API: [How to use the Query Manager](https://docs.supermetrics.com/docs/how-to-use-the-query-manager) - Data warehouse and cloud storage (Hub): [How to create a transfer](https://docs.supermetrics.com/docs/how-to-create-a-transfer) - BigQuery (marketplace): [How to create a BigQuery (marketplace) transfer](https://docs.supermetrics.com/v1/docs/how-to-create-a-bigquery-marketplace-transfer) ## More resources - [Yandex.Direct and Yandex.Metrica: Query setup guide](/v1/docs/yandexdirect-and-yandexmetrica-query-setup-guide) - [How to reauthenticate a data source connection](/v1/docs/how-to-reauthenticate-a-data-source-connection) - [How to manage data source connections on the Supermetrics Hub](https://docs.supermetrics.com/docs/how-to-manage-data-source-connections-on-supermetrics-hub)
